Off-Road Forums & Discussion Groups - View Single Post - Leaking Master Cylinder Cover
post #3 of (permalink) Old 08-23-2009, 11:51 AM
GoldToyBox
GoldToyBox's Avatar
Location: Selma,CA in the middle of the vineyards, Central California
Assuming you have a metal cap not plastic;
yes, they get bent/twisted/warped on the way to the re-manufacturer. They get cleaned & painted but not checked for an exact fit.
If you can find/see where it's leaking at .... a little tweeking with a block of wood (or ??) and a hammer usually does the trick.
Check the 'hold down' clip, sometimes it's not putting even pressure on both ends/sides of the cap. It gets bent up just like the caps. Adjust as needed.
Also check the gasket ..... sometimes they are malformed and will not seal properly.
If it's a plastic cap ................ find another one.
Good luck
"The Heep" 73 Commando, 258 I-6, T-18, Scout Dana 300 w/Tera 4:1 Kit, SOA, PS, Thru-dash Cage, Alcans, OBA, ARB's, HEI, Ft disc, MC 2100,Dents, Mud & Rust.
Last edited by GoldToyBox; 08-23-2009 at 11:54 AM. Reason: correct spelling & add more info
GoldToyBox is offline
