Off-Road Forums & Discussion Groups - View Single Post - Problems Finding Correct Tie Rod Ends...
post #5 of (permalink) Old 08-03-2009, 08:54 PM Thread Starter
TeamRush
TeamRush's Avatar
I have all the tubing bending, thick wall tubing, and taps, both right and left I can screw up...
That's not the issue.
I need to know if there is a 'DROP IN' tie rod end with the correct taper,
Or if I'm going to shell out for reamer that matches a reasonable priced, heavy duty tie rod...
I know someone MUST have done this before,
I've seen articles on guys using 1 ton TRE's in CJ's,
I just didn't pay attention to them because normally when I do a custom front end, I just drill the holes straight and use Heim joints and get it over with.
In this case, Since I street drive this little Jeep,
I want to keep actual TRE's in it to keep the steering somewhat tight...
So Many Cats, So Few Recipes...
TeamRush is offline
