Off-Road Forums & Discussion Groups - View Single Post - Problems Finding Correct Tie Rod Ends...
post #4 of (permalink) Old 08-03-2009, 07:19 PM
bandhmo2
Late 70's and early 80's Chevy/GM 1/2 to 3/4 ton trucks used similar TRE's. They have a bigger tapered area then CJ's but use the same taper 1.5" per foot. The treads are 7/8"-18. 1 tons used the same taper but the threads where 1"-18. You can ream out the CJ knuckles and Pitman arm to the chevy taper but it is slow and the cheapest reamer I have seen lately was about $60. Taps are available to make your own links but they are not a common thread so you will need to order them (MSC has them) and the left hand tape is rather expensive. If you have a large enough lathe I suppose you could single point them but single pointing a long inside tread like that would be a pain. Some outfits do make weldable bungs that are prethreaded and can be welded to the ends of your tubes, but I hate the idea of welding something like that on a highway rig.
If you run relatively stock tires and have not had a problem with bending tierods I would just go with stock Jeep TRE's.
If you do want to go to Chevy TRE's the cheapest way is to just order a set of rodends and links from Partsmike. That is what I am going to do and a love to make stuff myself but the last time I looked it was like $250 for Partsmikes kit and when you add up the cost of TRE's and the tools needed to make the links you get way more then that.
Wilhelm
bandhmo2 is offline
