Off-Road Forums & Discussion Groups - View Single Post - 04 Bruin 350 auto - possible piston slap
post #2 of (permalink) Old 08-03-2009, 07:34 PM
coley909
there is a coulple things you can do one get a valve adjusment you can pull the head off take it to a shop and have them measure the piston if it has scratchs replace it if its ovaled replace and hone the sleve no matter what you do if you do it before you blow it up it will save your top end from a hole rebuild also get your lifters and cranck checked for ware if your burnning oil your rings are or your vavles need and adjusment or you piston is scartched up only way to find out is to look aslo when you put it back together replace all gaskets itll sound like pinging if your vavles are offf clunking if your piston is bad just have to take a look
coley909 is offline
