Off-Road Forums & Discussion Groups - View Single Post - Ignition Problem (TeamRush)
post #5 of (permalink) Old 07-06-2009, 03:34 PM
Jim_Lou
Either the resistor is shot or the ignition system is drawing way too much current. I definitely would not try running without the resistor.
Disconnect one end of the resistor and then check its resistance with your meter. The '78 Jeeps used a resistance wire instead of a discreet ballast resistor. The '78 FSM says that the wire should have 1.35 Ohms. If you get a reading considerably higher than that, replace the resistor.
B. Dash Fabrication
Jim_Lou is offline
