im gonna go get another cheap gauge tonight....this one was only a few weeks old...
Quote:
If you want to set your carb up,
Hook up to the baseplate of the carb...
where is the hook up on the base plate?
i've got the stock intake manifold, and a mr. gasket adapter plate for the mc2100
on the intake manifold, below the throttle linkage there is cube shaped brass fitting, it feeds vacuum to the brake booster. There is some serious vacuum coming out the other side of that fitting. I've had it capped off since i've owned the rig. Should i take the vacuum reading there?
Thanks again for contributing on this forum!
Tim
