You may not have one. Look for a spacer about a half inch thick with a 5/16" shaft through it between the collector and the down pipe. Grab the shaft with pliers and see if it turns. If there's no spacer or the shaft turns the problem is something else. In that case, look for the link to RRich's Propane Trick in the welcome post.
