Off-Road Forums & Discussion Groups - View Single Post - Wiring electric fan for thermostat and dash toggle???
post #48 of (permalink) Old 04-30-2009, 04:47 PM
bandhmo2
Warthog, sorry I did not see this post sooner. Here is a little picture of what you want. Top position on the switch is always on, middle is always off, and bottom is auto. The numbers next to the relay are the numbers used on Bosch type relays if that is what you are using. This drawing assumes that your thermal switch has a switched hot run to it and it closes when up to temp. If your thermal switch grounds when up to temp let me know and I will post a new drawing.
Hopefully, this helps you.
Wilhelm
bandhmo2 is offline
