Off-Road Forums & Discussion Groups - View Single Post - Wiring electric fan for thermostat and dash toggle???
post #2 of (permalink) Old 04-22-2009, 12:18 PM
CJ7Taz
Official Curmudgeon
CJ7Taz's Avatar
What would you like to use, a toggle or rotary switch?
You need a single pole - double throw with center off position switch (center off because that is common). You could also use a three position switch like a Jeep wiper switch or 3 position fan switch. You wire the load to the common lug and the different sources to what is normally the load lugs.
I would assume your temp sensor provides a ground when the set temp is reached. That means you need to wire +12v power to one side of the relay. Wire the other side of the relay to the common lug on the switch. Wire your temp switch to a lug and wire the remaining lug to ground.
CJ7Taz is offline
