Off-Road Forums & Discussion Groups - View Single Post - 5.7 Vortec Wiring harness - Painless or use factory
post #2 of (permalink) Old 04-20-2009, 02:46 PM
TeamRush
TeamRush's Avatar
Quote:
Originally Posted by dugs_cj3a View Post
I recently picked up a 98 5.7 vortec, ecm, and wiring harness and plan to install in my CJ5. I've been doing a little research and I know given enough time I can hack up the factory wiring harness to work. My question for those of you that have done this before, if you had it to do all over again would you have spent the money and purchased a Painless wiring harness?
Thanks
Doug
What 'Factory Wiring' do you think you have to 'Hack Up'?
All you really need from the factory harness is the 'Ignition' power feed,
the rest for the fuel injection sensors, injectors themselves, ect will NOT be in the factory harness since there is no fuel injection...
And there are SEVERAL COMPANIES that makes Fuel Injection harnesses to run between sensors, components and computer...
The one I like the most is from Arizona Speed & Marine, but there are SEVERAL...
Now, if you mean the factory Jeep wiring is crap and needs replaced,
I'd agree with you on that point,
BUT,
For factory replacment harnesses, I sure wouldn't use Painless when there are so many others out there so much cheaper and just as good or better...
TeamRush is offline
