Off-Road Forums & Discussion Groups - View Single Post - 92 Wrangler 2.5L clutch bleed screw
post #5 of (permalink) Old 04-17-2009, 09:06 AM
Jim_Lou
Soak it in penetrant first. I prefer Kroil, but PB Blaster works well too. Don't use WD40 - it's useless. Use a 6-point socket, not an open-end, box-end or 12-point. If it doesn't open readily, let the penetrant soak in longer. It might take a couple of days. Finally, if nothing else works, heat around the fitting as best you can with a torch and then try. If it still doesn't open, add penetrant as it cools and repeat the cycle several times.
B. Dash Fabrication
Jim_Lou is offline
