Off-Road Forums & Discussion Groups - View Single Post - axle flange slugs for scrambler full floater
post #5 of (permalink) Old 12-11-2008, 10:35 PM
bandhmo2
Those have the correct inside splines, however the outside is too big. I do not know if they are big enough to cut off the old splines and recut at the correct size. I had planed to get a set and give it a try, since I can cut my own splines. However, I could not find any for less then about $90 and thought it better to just get new ones than risk it and take the time to respline. Given that you will need to buy them and than get them splined for $ I doubt that you will save any money on this. Resplineing these will likely cost more than an axle as axle resplineing is at least somewhat common and Moser and Dutchman are set up for it. If you plan to get them resplined for $ get a quote first, they will likely have to make fixtures to do it.
Wilhelm
bandhmo2 is offline
