Off-Road Forums & Discussion Groups - View Single Post - Fuel Cell Set-up
post #2 of (permalink) Old 08-02-2007, 09:39 PM Thread Starter
KentuckyCrawler
Well, my regulator came in yesterday for my set-up so I took a piece of 2.5" flat stock and mounted my filter, pump, and regulator to it then bolted the flat stock to the Jeep body right above the rear frame crossmember.
It should be well protected there, but I will install a flat skid at the frame for extra security.
I wired the pump up to my factory harness and ran all my tubing. I need one more fuel line hose clamp to tie into my factory fuel line, but I had the wife turn the jeep over to check flow and it looked good.
Hope to have the fuel cell secured to the tub tommorrow, clean-up all my wiring and tubing then get the Jeep moving again!!!
Brad
2001 TJ Built, Wrecked, then Built Bigger, then rolled and fixed again, now rolled again. Do you see a pattern!!
KentuckyCrawler is offline
