Off-Road Forums & Discussion Groups - View Single Post - I would like a GOOD GOUND for my Alternator
post #4 of (permalink) Old 06-23-2007, 11:56 AM
TiminMb
I'd run it from a bolt on the body of the alternator right back to the negative terminal of the battery. I have a ground cable from the negative terminal to a bolt through the firewall where I have a second cable to the dash (metal dash on a cj). It might be overkill, but who could fault someone having separate grounds to the block, grill, firewall, dash, starter solenoid, alternator? If you have the time, go for it. A common brass terminal on the firewall might be a good place to branch out from for smaller secondary grounds, and I'd run a heavy separate one to the block and alternator.
TiminMb is offline
