Off-Road Forums & Discussion Groups - View Single Post - 92 4 Door Laredo Replace Drivers Window Regulator
post #2 of (permalink) Old 07-08-2006, 10:40 AM
Andytron
Re: 92 4 Door Laredo Replace Drivers Window Regulator
You are better off asking on the mid-size board. This board is for the full size Cherokees and does not get much action. I have never done a window regulator in an XJ but it shouldn't be too bad. Obviously you'll have to pull the door pannel and the window off/out. Then you will need to remove the rivets holding the old regulator in. Instalation will be the reverse of the removal. If you can get a look at the factory manual it will give you a good idea of what needs to be done. What exactly is wrong with the old regulator? Is it the front or rear door? Power or manual? This might help. http://www.discountjeepparts.com/pro...ducts_id/23745
Andytron is offline
