Off-Road Forums & Discussion Groups - View Single Post - rear brake problems
post #3 of (permalink) Old 03-23-2006, 01:56 PM
LEVE
Re: rear brake problems
Remove the drums and the adjuster assembly. If it can't be turned by hand it will not work. You've got to clean up the adjuster and keep it lubed. I've used both wheel bearing grease and (when in Wisconsin) anti-seize compound. Also, check to make sure the drums are not out of spec. The adjuster can only do so much.
