Re: Early Bronco axles into a TJ...
One thing that does come to mind, IIRC - EB axles are only 51 or 55" WMS - your TJ is right at 60" WMS - are you sure you want to go *narrower* ?!?!?
If you have 2nd gen Bronco axles they will be wider.
There are better options, but since you already have these. They will work.
If you are a (very) good welder or have a bud that is.
This is NOT a job for a shade tree welder!!
First -
Buy stock in grinding wheels as you will have a lot of grinding ahead of you to get all the old bracketry off the Ford axles.
Next -
Get a bracket kit from one of the major players like RE or Teraflex.
Then -
Make a jig so you can get all the brackets lined up correctly - VERY IMPORTANT.
After that -
Install, debug, debug, repeat as necessary.
