Pooh-Bah
Re: ARB Air locker rear-end problem
We pulled the dented cover off a buddies 60 and there was small metal pieces in there from the ARB also, turns out they were retaining tabs pressed onto the bolts holding the ARB together and they were knocked off from the cover. The guy that built the axle said it "should" be okay w/o the tabs because they use locktight on the bolts as well.
