Re: 4 wheel drum lines...
Agreed, I had known that there should not be a prop. with a 4-wheel drum setup...I was guessing that it did nothing and was only there for the break warning light.
I know that on a "front disk/rear drum" setup the front disks are run off the back port on the MC.
The real question is, Do 4-wheel drum breaks work the same? Front drums run off the back port of the MC?
On a side note, two other things are funny about my setup.
1. The front axle has been replaced (Still has the junk yard marks on it.) With one from a 78 CJ5. Maybe it really had disks to start with.
2. The MC has a larger line going out of the rear port. (I think it's the rear port)
Tucker
