Off-Road Forums & Discussion Groups - View Single Post - Dead Bronc! HELP!
post #2 of (permalink) Old 08-25-2005, 12:32 AM
FoundOnResDead
Re: Dead Bronc! HELP!
Try looking for a bad ground or ground wire off in that area. I just fixed a 1986 bronco with the same problem and it turned out to be a ground wire was off. Use a DVOM (digital volt ohm meter) and test from the battery positive to the engine block, while having it set at VDC and see if you have 12.0 to 12.6 volts.
FoundOnResDead is offline
