Off-Road Forums & Discussion Groups - View Single Post - At my wits end with 2bbl motorcraft NEED HELP!!!
post #3 of (permalink) Old 06-23-2005, 04:11 AM
JWharden
Re: At my wits end with 2bbl motorcraft NEED HELP!
Check that there is no debre in the needle and seat, check gasket/washer under seat for cracks. Also check the carb bowl
where the seat threads in for cracks. If no cracks put it back together make sure you have the seat tight, but not gorilla tight, you don't want to split gasket or crack bowl. Has teflon tape been used on the fuel line threads ? If so remove all of getsome liquid teflon for the fuel line fittings.
Sometime little pieces of the tape break off and interfear w/ the needle and seat seal.
Hope this helps
JWharden is offline
