Off-Road Forums & Discussion Groups - View Single Post - tow vehicle ?'s
Thread: tow vehicle ?'s
post #1 of (permalink) Old 05-07-2005, 09:23 PM Thread Starter
Hank
Hank's Avatar
tow vehicle ?\'s
Hey guys...
I posted this on the Chevy board, but no luck.
My '93 Suburban K2500 4x4 needs some basic work. The front rotors need replacing - is there any magic way to get them off or will the truck have to go to a shop to have them pressed off the hubs?
Next ? - the rear cover on the 14 bolt is welded on (it's a used truck I bought some time ago) - are the axles true Semi floaters or does it have c-clips? I have a leak on the passenger rear axle seal at the wheel - it appears that the oil seal is at the end of the axle tube and there is no bearing retainer plate...is that correct? The bearings are pressed into the housing and ride on the axle shaft directly - right? One seal is leaking bad(!!) and I need to change it out and check the bearings while I'm in there.
Hank is offline
