Off-Road Forums & Discussion Groups - View Single Post - Another 258 GM TBI post -- chip burning / files???
post #8 of (permalink) Old 02-25-2005, 09:07 PM
RRich
Re: Another 258 GM TBI post -- chip burning / files???
Exactly!!!!
The difference of 4 cubic inches is not going to make a significant difference!
The problem folks have from Howell is they use mechanical HEI - or whatever distributor is already there - it's not able to be controlled by the ECM. The result is often ping and detonation. Do a search on this board, see for yourself.
Use the EST type module - the 7 pin HEI distributor.
Howell doesn't even provide the wiring for it.
Make sure you use the KNOCK SENSOR with it - mount it similar to the stock one -- that's VERY important.
Howell and the others make a big deal of "recurving" the fuel curve -- "smoke" to get you to buy their stuff - it's been proven time and time again the stock original chip works the best.
Howell has no idea about engines -- they tell you to plug up big holes in the TBI/manifold's adapter with silicone!!! Even a high school kid knows that only holds for a few minutes.
They may know how to shorten or lenghten a wiring harness, but they should stick to that.
RRich is offline
