Re: Transmission rebuild - how much?
I don't mean to make you mad but i know around here you can't get them rebuilt for that i do transmissions but i had really tryed to stay away from the th700 there is a lot of piecse in one of those compared to a 350th
but I have a guy that is comming in that talked to an old boy over in another town that said the only way to go is to bypass two of the valves in the valve body. I told the if he gets the info on it i would do it but I would not put my name on it. This guy has been through 3 trannys and he is hopeing it will fix it I will let you know how everything comes out. As far as energy suspension mounts go the only thing bad i have been told about them is that they are pretty hard. Other then that every thing is good
