Off-Road Forums & Discussion Groups - View Single Post - My attempt at the HEI conversion
post #6 of (permalink) Old 01-15-2005, 10:00 PM
OlllllllOCJ
OlllllllOCJ's Avatar
Re: My attempt at the HEI conversion
The box is a good idea. I had been looking at those types at Lowe's but found something else at Radio Shack.
I'm with John on the splices, better off inside the box and a grommet would make it perfect.
Actually I don't care much for those type splices and would solder the wires together and use heat shrink. But that should work.
I see that you used a harness for the TFI coil. That makes it cleaner and more vibration proof. Didn't try the fuse holder harness thing huh (that's OK, I will).
Don't see a heat-sink in the pictures, did you cut a hole in the box so that the heat-sink is outside in the cool air?
Hope you don't mind if I steal your pictures (sooner or later).
Dale
OlllllllOCJ is offline
