Off-Road Forums & Discussion Groups - View Single Post - Puegot trans to AX15 swap??
post #4 of (permalink) Old 01-10-2005, 11:42 PM
OregonSahara
Re: Puegot trans to AX15 swap??
If the AX-15 was out of a TJ the clocking should be correct. You will still need the 23 spline input for the T/C. Your skid plate may also need to be drilled as well.
One advantage to one out of a TJ should be an external slave cylinder. Hopefully you have all of the brackets/shifters.
OregonSahara is offline
