Re: spray on bed liner ?
Every once in a while i work for my uncle who owns a shop that does spray on bedliners. Prep work is key. If you prep it good it will stick, otherwise you may have problems. We spray Ultimate linings which is a sticky liner, and also Arma coatings which is harder and doesnt grip as well. Seems like the hippo is like the arma becuase its a hot high pressure spray so i think it ould work well if you did it yourself. Good luck.
Later
