Hello,
Can anyone tell me "about" how much power a 2003 Grizzly should have? I assumed that the 660 would scream but it doesn't. Top speed on flat surface is 48mph.
I bought a used one from a dealer... of course there are NO test rides so I had to put down almost $6000 including tax & license before I could "test" it.
I am very disappointed as it seems to be very sluggish. It will not bring the front tires off the ground, it barely spins the rear tires from a stop, I have to use low range for steep hills as high range bogs.
Also: I stopped on the road to take some pics of it and it started smelling hot. It smelt like a boiling radiator (antifreeze) smell. I did not see any antifreeze on the ground. The outside temp was about 20F and I was playing on logging roads.
I can't get it into Park unless I turn the engine off. Is this normal?
Thanks for your time.
- Ron
- Ron
