Off-Road Forums & Discussion Groups - View Single Post - body lift or susp?limited slipes?
post #2 of (permalink) Old 11-23-2004, 04:50 PM
tanbuddy
Re: body lift or susp?limited slipes?
A 4" lift would probally be too high for 33s w/ 35s it would look good.
If u run the 33s go w/ a 2". I think the 2.5 has all the brackets which is a lotta work when u can get a 1.5 or 2" coil spring or a coll spring spacer. Would also be the cheapest route. Add a leaf in the back if u tow heavy, or else just a little block for lift. I would run them with the stock wheels or 15x8s at the most.
A better set of shocks could help, but the stockers should work fine.
Not sure about a l.s. but any is better than the stock one.
tanbuddy is offline
