Off-Road Forums & Discussion Groups - View Single Post - GTI intake manifold (EFI) runners.
post #2 of (permalink) Old 06-05-2004, 12:50 PM
szki272
Re: GTI intake manifold (EFI) runners.
it might be possiable to cut and weld although it would probably be better to build a adapter out of 1/2 or thicker or 2 pieces of 3/8 or thicker usually when the shop I worked at built carb adapters we used 2 pieces of 3/8 machined one to match the carb the other to the manifold then we blended the two together the same probably could be done at the intake
but the cost of building such as a kit would probably cost as much as doing the feul injection unless parts of the injection system are missing or broken
I think you will also need a 8 valve swift distributor since the 16 valve is avanced by the computer insted of vacume
szki272 is offline
