im not sure which tranny was put in that year yj with the 4.2, if its the aw4 you wont have a problem and i dont think you would have a problem swapping to another factory auto... im almost positive it will go
Yes they will bolt up with no issues,,,,BUT,,,, are you sure you are looking at an NP231 and Not an NP207? But otherwise they have the same spline count and bolt patern.
Ditto with GP'N. I've been checking this out for a while on manual trannies. The '87 <nobr>Cherokee</nobr> had a NP207. Otherwise, the differences aren't in the T'case bolt holes. They are in the way the rear tranny bolt holes are laid out.
I would stay away from a 207 but a manual i6 '87 Cherokee should have had a 231. Find a nice 231 and count the splines. There's 21 and 23 spline shafts. Manual '87 and '88 (BA peugeot trans) i6 have 21 spline TC's. Later ones with the AX15 trans have 23 splines. Auto's have 21 as well as 23 splines mixed through the years as far as I know, so always check.
there are nv231 the wrangler has a 999 in it and i dont know what the comanche has in it i want to do a sye on the wrangler but i am not done lifting is so i dont want to do it to that and then haft to buy 4 drive shafts i was going to do it to the comanche t-case and then move it to my wrangler when i am ready for it the comanche is a parts truck i drive my wrangler every day
Related Threads
Off Roading Forums
1.4M posts
22.4K members
Since 1999
