Off-Road Forums & Discussion Groups - View Single Post - What D44 will accept TJ D30 knuckles?
post #6 of (permalink) Old 03-12-2004, 07:11 PM Thread Starter
gigolo
gigolo's Avatar
Re: What D44 will accept TJ D30 knuckles?
Will, thanks for the info. I'll see what I can find out about the dodge 44's. I don't suppose you know where I could get those kind of specs?
Andy, I've already replaced that bent 30, twice actually. Replaced it completey, then swapped that with one from a buddy's '02 tj that had 4.56's. I've had the bent one sitting in the corner, but we're trying to clear out some space, so I stripped it down. I thought I remembered it being discussed that there was a 44 housing you could use, but with everything from the knuckles out off a tj d30. I figured if I could get the right 44 housing, then all I'd need is the inner shafts, gears/carrier, and the one control arm bracket that goes over the pumpkin. The sale of the d30 with 4.56's should recoop most of that cost. Am I dreaming all this?
gigolo is offline
