Off-Road Forums & Discussion Groups - View Single Post - Key in the Ignition Buzzer??
post #1 of (permalink) Old 03-09-2004, 10:13 AM Thread Starter
gjk392
Recently Ive been having a problem with my battery draining after a few days when I leave my key in the ignition (parked in garage). I tore apart the steering column, checked out the ignition switch on the column, tested the alternator, made sure the radio turns off, checked and made sure the amp turns off (gets signal from radio to turn on); made sure the battery is still good.
Did an 82 CJ7 come from the factory with one of those buzzers installed that tells you the key is in the ignition? Is there something else I should look for? Other then the obvious solution of removing the key I have not been able to locate the problem.
gjk392 is offline
