Off-Road Forums & Discussion Groups - View Single Post - ----Is my Jeep running 180 degrees out of phase???
post #2 of (permalink) Old 03-07-2004, 07:21 PM
Skip
Re: ----Is my Jeep running 180 degrees out of phas
If those 2 wires were wrong it shouldn't run at all. Did you pull the distributer out, or replace the plug wires and get it 180 out? That's the only way you could be 180 out.
Remove coil wire, remove the number 1 plug, hold your finger over the plug hole, bump the motor with the starter. You'll feel compression stroke, line up the timing mark, now you can verify plug wiring.
Good luck
