Off-Road Forums & Discussion Groups - View Single Post - ----Is my Jeep running 180 degrees out of phase???
post #1 of (permalink) Old 03-07-2004, 05:08 PM Thread Starter
pnut
Orange from Distributor = minus (-)??????? Is this right?
Purple from disttributor = plus (+)?????? Is this right?
1982 CJ7 with MSD, stock dist, MSD coil, Howell TBI.
I just rewired my Jeep custom (Nov to now). Before the rewire it ran perfect. Now I started it and it "runs" horrible for few seconds only. I get spark, and I have confirmed the fuel pump is OK. However when I do get it to "start" is runs rough, and backfires though the carb. It almost sounds VERY lean. I THINK it may be running 180 degrees out.
So to make 100% sure I need to know the polarity of the distributor wires
If I had the distributor wires switched, would my engine run 180 out, and cause the symptoms I describe? Could I have caused any damage?? (It made a horrible crunch noise after the 3rd time I tried to start it)
If I had the coil hooked up wrong, or a mixed TFI wire, would that cause such a problem?
Thanks guys, need your help here to make sure.
pnut is offline
