Re: Lower Ball Joint and Alignment Issue
For $247.00 you could buy ALL new ball joints,(look at
www.jeepdoc.com) an inexpensive ball joint press from Harbor Freight($39.99), the spanner socket for the preload nut on the upper ball joint($9.99 jeepdoc again), and I`m sure you could borrow a torque wrench from a friend if you don`t have one, or go buy a new Husky at Home Depot(39.99). You`ll still have more than enough money left to buy a case of your favorite libation. Its not a hard job to do and you`ll gain valuable experience and confidence from doing it yourself. Good luck.
