Off-Road Forums & Discussion Groups - View Single Post - BRAKE FLUID RES. SLUDGE(YOGURT LIKE TOP LAYER)
post #6 of (permalink) Old 03-06-2004, 07:42 AM
Jim_Lou
Re: BRAKE FLUID RES. SLUDGE(YOGURT LIKE TOP LAYER)
It could be that someone mixed DOT 5 (silicone) fluid with regular DOT 3 or DOT 4 glycol-based fluid. That will produce a mess like you describe.
The proper cure is to remove all the seals and cups, flush the system with alcohol and then new pure fluid, and then replace everything. And if I were doing that, I would use DOT 5 when I put it back together. It's great stuff and perfect for a Jeep since it won't absorb water.
Jim_Lou is offline
