Off-Road Forums & Discussion Groups - View Single Post - weber accelerator pump
post #3 of (permalink) Old 01-02-2004, 08:33 PM
Sarge
Re: weber accelerator pump
First , don't use compressed air , back flush it with carb cleaner to wash out any particles so they will show up in the float bowl . Then, stop playing with the accelerator pump because the dirt problem is in the primary idle jet . If it's plugged at all , that hesitation will show up there . If you can't get any dirt to show up from the accelerator pump and the idle jet is clean , get a timing light out and verify that the vacuum advance is working . All three of these things together or alone will cause that problem , they work as a system .....
Sarge
Sarge is offline
