Off-Road Forums & Discussion Groups - View Single Post - Chevy 3/4 ton running gear in jeep
post #8 of (permalink) Old 09-10-2003, 02:16 AM
W.C.
Re: Chevy 3/4 ton running gear in jeep
If the rear is an Eaton, you can build a bitch'n hy-bred axle with it and 14bolt parts. The Eaton shafts are only something like 17 spline(?), but 30 spline 14bolt shafts, hubs and spyder gears fit the Eaton housing and carrier. And even the 14bolt Detriot will fit. The stamped steel, Eaton housing only weights 75 lbs and has better ground clearance then the 14bolt.
W.C. is offline
