Off-Road Forums & Discussion Groups - View Single Post - kasea 90
Thread: kasea 90
post #2 of (permalink) Old 08-05-2003, 09:57 AM
tony1034
Re: kasea 90
Not sure how good your dealer is, but he should take care of it for you. After all it does have a warranty. Some dealers add oil to the first tank of gas for it to break in. Its not necessary, but some just do it. Make sure they filled the oil tank with good synthetic two-stroke injector oil only. Don't use pre-mix oil. You can go to Walmart and pick up some extra plugs. Get the NGK B7HS plugs (stocker is BPR7HS, but you don't need the "r" resistor or "p" protruding tip. Keep an eye on the air cleaner and make sure its clean and oiled (but not over-oiled).
Good luck,
Tony P.
