Re: rear disk brakes finally work GOOD
I took the stock combination valve apart and got rid of the plunger. This causes fluid to leak out, so i welded the weep hole shut (tiny hole)
Are you still running the fronts through the valve?
If you are you no longer have a split system and if you blow a line you'll loose pressure in both front and rear. Not sure if you knew that so I thought I'd mention it just incase.
