CJ LIFT
I know this will probably sound pretty pathetic but I'm tryng to figure out if my CJ 7 has a suspension lift(leaf springs) on it. I've read the threads on tire sizes and the lift needed to use certain sizes. Mine has 33x12.50 and has quite a few inches between the top of the tires and the top of the fender wells. Reason being is the steering is non resposive and all over the place. Replaced 3 tie rod ends(which were bent), removing the longer shackles and installing stock tommorrow and will have a new steering stabilizer in a day or two. The pitman arm is still stock and the angle from there to the knuckle is around(best guess) 15deg or so. Real new to the jeep thing but want to learn.
