Off-Road Forums & Discussion Groups - View Single Post - Trac lock axle shaft wheel bearing problem
post #3 of (permalink) Old 07-20-2003, 06:57 PM
pontiac58
pontiac58's Avatar
Re: Trac lock axle shaft wheel bearing problem
Jack just the side up with the axle that wont go in. Leave the tire on the other side, leave it on the ground and block the tire. Take a BIG crow bar and put it between the lugs of the axle that wont go it. Turn and push at the same time. You have to line the splines up again. The only other way to do it is to take the trac loc apart and rebuild it and line up the splines that way.
When your done that said, take the other side apart and put bearings in that side.
pontiac58 is offline
