Re: Need help with my speedometer cable
I went through a similar delima a while ago. What I did was get a drill motor and put the cable in the drill and watch the speedometer make a note of the reading , now do the same for the donor cable and speedo if you have it. If they are the same and IF the speedometer ends are the same then you use the donor cable.
