Off-Road Forums & Discussion Groups - View Single Post - Lifting This Weekend. Last Minute ???
post #10 of (permalink) Old 07-18-2003, 02:16 PM
Re: Lifting This Weekend. Last Minute ???
Hooch,
"The only thing that could cause a problem are the military wraps i.e. that they physically won't fit as the spring eye is too close to the spring hanger. Measure how much room you will have left when both the spring eye and the spring hanger are inserted into the shackle. You might require slightly longer shackles but don't go overboard with the lenght as it will affect the caster of your front axle and give your Jeep a wandering feeling on the straight."
See, that's what I'm worried about, the springs not fitting.
Let me ask you this, cause I'm a bit confused. You said that I can run stock shackles for now and upgrade later, but then you said that they won't physically fit. Are you saying that the spring itself will fit, its the military wrap that won't? I'm a bit confused because I've never seen a military wrap before. [img]images/graemlins/tongue.gif[/img]
Thanks!
