Off-Road Forums & Discussion Groups - View Single Post - Lifting This Weekend. Last Minute ???
post #3 of (permalink) Old 07-18-2003, 08:09 AM
babypoo
babypoo's Avatar
Location: Milwaukee(which is algonquin for the good land)WI U.S.A
Re: Lifting This Weekend. Last Minute ???
Congratulations on the lift...You are now experencing why Jeep stands for
Just
Empty
Every
Pocket
Anyways to answer you questions:
1. Any type of grease should work (as it's been said)
2. Jack stands should be placed on the frame the best place will probably be close to to te inner most spring perch(as was also said you will want a second set for the axle)
3. Good job using the Chiltons that's what it's there for.
PB Blaster is a must soak, soak, and soak again this will make your life much easier.
Did you find out what your squeak was????
John
[email protected]
babypoo is offline
