Re: Need pix of TJ D44 rear brake assembly, please
Thanks LEVE,
I had seen that diagram in the 2001 Shop Manual but I noticed that it says "Brake Diagram - Typical". It also doesn't look exactly like my assembly, so I wasn't sure if was the same as mine or just sort of similar to mine. Thank you though. I will check my assembly with the diagram tonight.
