Sarge Rules!!!
sarge is a great guy. he has worked through the first few weber probelms i have had. the first pump was bad, second pump bad, bad regulater, bad guage, problems with hesitation, problems on angles, and sticking throttle shaft. he has worked through all that stuff an d now it is finally almost running right. i had it tipped over on its side and it was still running just fine.
the only probel i still have is the sticking throttle shaft. after a few calls to him i tried the fix, and it still was sticking. i called him saturday and told him i have the throttle adjusting nut so loose and not even tight and the throttle still sticks at the carb, and this afternoon sitting on my door step was a bracket and spring for a throttle return!
great guy who works with the problems i had!
Thanks Sarge!
