Re: What do these numbers stand for?
By the numbers 44-1 and 30-1, you definitely have a 30 front & 44 rear. The other numbers can't tell me what you have. There should be a 6 digit number then a dash, then a 1. Thats the number you need to find. It'll be on the longer axle tube about midway towards the drums, facing the diff cover side (usually). Are they 6 lug or 5? If six, then they're waggy axles. If they're five lug, it sounds like you either have cj axles or Commando axles. What width are they? Waggy axles are around 58-60". I attached a file with all the BOM#'s. Just look up the number from your axle and it'll tell you what you have. Just disregard the -1 as the BOM's don't have it. Hope this helps!
Bill
