Off-Road Forums & Discussion Groups - View Single Post - engine question
Thread: engine question
post #2 of (permalink) Old 04-22-2003, 08:54 PM
BRONCOMANIA
BRONCOMANIA's Avatar
Re: engine question
No, its not possible unless you got octopus arms cuz you cannot *fully* remove the oil pan under a bronco even jacking the engine as high as possible with the upper intake off, anyways, if your main bearings are bad enough the rods are even gonna be worse as they recieve lubrication after the mains. Sorry , been there already [img]images/graemlins/frown.gif[/img], its simply not worth patching the lower end on a 5.0 in a 4X4 truck unless you plan to put a for sale sign on it the next day. [img]images/graemlins/smirk.gif[/img]
If your main bearings on a 5.0 are bad, most likely your rod bearings, your oil-pump, timing chain , rings & seals are not much better or worse.
BRONCOMANIA is offline
